You want to cap the ports, not loop the hose. If you loop the hose you'll give yourself a high idle.nice! so since i deleted my ac system-compressor, evaporator, condenser, is it right and possible to.remove it and just route the hose from the intake tube to the plenum?
thanks! i figured that out too.You want to cap the ports, not loop the hose. If you loop the hose you'll give yourself a high idle.
