Does anyone have the possibility of measuring center to center top nut on rear struts for a st205? I am interrested in knowing if there is difference in strut tower width between st205 and st185. I have measured my st185 to aprox 1100mm between nuts
You also have the non-adjustable?I use the st205 brace on my st185. They are the same distance. The st205 extra rear track width happens in the strut/knuckle connection.
Yes, OEM non-adjustable for an st205. You used to be able to buy them from the dealer, even in the US.You also have the non-adjustable?
