The jumper is a factory one from a FWD Celica, it was snug before but I'll double check it still is.
alltracman78":1jwrx5d0 said:
The AFM isn't the problem. They're probably confusing with the 165. IIRC The fuel pump circuit runs through the AFM on those. That's the safety, instead of from the ECU like the 185 and up.
The only way I could see it mattering is if the ECU is using the signal from the AFM to decide what to do with the FC pin to control the COR.
There may not even be that many (7) differences between the homologation and the 92/93 (facelift) pinouts. And the differences are things like EGR , EGR temp. Plus of course the IC level sensor. Nothing to do with the fuel pump. I have the pinouts for both, but not in front of me. The ECUs actually have the pinouts printed on the board FYI. You can open the top cover and read them. I forget if the second board (on the facelift ECUs) is in the way or not. I don't think so.
Some of them I can find descriptors for, but others I have no clue. The RC apparently has:
EVP - ???
ISCV - ???
RLY - ???
ECO - ???
ACT - ???
ATS - ???
CCO - ???
WIN - Intercooler ECU
that the USDM doesn't have.
The USDM has:
HT - O2 heater
STJ - Cold Start Injector
EGR - EGR VSV
that the RC doesn't have.
I doubt it will do anything for this issue, but don't forget you can put the ECU into a more sensitive diagnostic mode by jumping TE2 and E1 and drive with the jumper in place. Benefit of having a facelift ECU.
I might have to try that next to see if it can find anything.
Did you check and see if the ECU was still grounding FC when the pump stopped working?
I tried, I can report back that with the probe stuck into the back of the plug with the COR installed it reads a bit of resistance and voltage to ground when running. That was annoying because I couldn't just leave the meter on short test and listen for the beep to stop as I drove around. If you switch the engine off and the key to ON it shows 12V as expected. The car did shut off once, but when I coasted to a safe spot to look at the meter and crank the engine it just fired up and ran normally the rest of the evening. :bangshead:
I don't have any other info about the FC circuit specifically, but I can't imagine it's any more complicated than the ECU sees the engine rotating (from the dist) so it grounds the circuit.
The wiring manual has info on checks you can do for specific circuits. Tells you what voltage or resistance to look for for specific wires. It's on the page after the diagram. Or second page maybe. Probably won't give you anything but worth a look.
That's the issue I'm having, there's no info on the FC circuit. Correct operation, testing procedure, functionality, nothing. The only place it's mentioned is in the terminal list: FC - Circuit Opening Relay.
Thinking about this, I doubt it's the dist. If the ECU isn't getting an RPM signal it shouldn't send an ignition signal to the igniter either, which it obviously is if the engine runs with FP and B+ jumped./quote]
I would expect it to throw a code for that too (same reason I was doubting the AFM), since there's 2 possible codes for dizzy faults.
It's also possible one or more of your engine harness grounds is bad or corroded. Anything that grounds through the ECU (like your injectors or the COR) ultimately grounds through the E1 and E2 wires. If there's a bad, damaged, or corroded splice or connection that will effect how much voltage things see. Too little voltage and things won't work, like the COR dropping out. Wouldn't hurt to do a voltage drop test on the E1 and E2 wires. I wouldn't suggest checking resistance, doing that can sometimes miss only partially damaged wires. A voltage drop test will let you know if there's an extra load (in this case damaged/corroded wire).
That's another good thing for me to check, the inconsistency is killing me though. I much prefer when something breaks and stays broken so I can just find it and fix it lol.
