If you want to set the Alltrac up with the historically correct shoes, here are some options in late 2024:
TIRES: These can be hard to find. Hoosier makes gravel rally tires, in a variety of R15 sizes in left and right hand tread patterns--cool huh!? Probably most relevant would be the 195 or 205 65 r15 offerings. These are not so large that they would require any fender modification. I run a 205 50 r16 which is 24.1 inches tall. The 195/65r15 is 25 inches tall and the 205/65r15 is 25.5 inches tall. I believe that the narrower tire is more correct to what was run in the glory days of WRC.
https://www.hoosiertire.com/assets/Rally6.pdf
WHEELS: Sadly, neither Sparco nor OZ offers 15 inch wheels anymore. You could of course just rock the OG oem 15 inchers. Black Rhino does offer some rally wheels. I like the Voll and the Boxer. Both are available in 15x7, 5x100 bolt pattern. The Boxer is lighter at 17 lbs, but is only in black. The Voll is 20 lbs but comes in hyper silver, bronze, and black.
https://www.blackrhinowheels.com/black-rhino-hard-alloys-boxer
https://www.blackrhinowheels.com/black-rhino-hard-alloys-voll
I priced out a set, sourced through my local friendly Les Schwab, and if you want to rock the historically accurate shoes--say you're doing SCCA rally cross (Monachopsis)--it will run about $2500. Pimpin' ain't easy.
