So I have to get my car realigned as some of you know and after looking around I saw it was popular and really helps the car to ever so slightly toe out the rear. 2 examples are -0.8 (assumed degrees) and then someone else said -1mm. Super slight, however visually looking at my car it's super toed in the rear. I'm worried about stability...
The alignment I'm thinking about
FRONT
+0.1 degrees front TOE
as much negative camber as the stock system allows (likely 0)
(when I get coilovers and bolts -1.7)
REAR
-0.08 or -0.1 TOE
(when I get coilovers and bolts -1 to -1.7)
Who runs something similar like this and how does it do? Does it make the car unstable at speed? Any help is appreciated.
I've been running it in SIM for sometime and getting really fast and stable times but the SIM can only tell you so much
FRONT
REAR
-0.08 or -0.1 TOE
