CosmicWanderer
Well-known member
- Joined
- Jun 30, 2024
- Messages
- 61
Hi, for those who don't know, here's my introductory post and now the time has came to start to repair the engine. Took almost half a day to pull it out, considering the car was rotting for 20 years, no parts, except inner CV joint, were damaged. The CV had its balls bearings flying out, but I think I saved that as well. Lucky. Maybe.
So far so good. Holy sh*t though. This engine is pretty much complicated, considering my experience seen in lots of Mercedes-Benz, VW, Audi, BMW, Renault etc., engines. Especially the wiring harness and coolant hoses.
I have yet to remove some remaining coolant hoses near the dizzy, see if I have to remove oil pump, water pump, and then start to remove valve cover, then camshafts and.. cylinder head. After removing the intake manifold, I can see through the valves that the piston #3 is catastrophically damaged. Each minute passes by, I'm eager to know what the hell is going on to cause 0 psi compression. A hole in piston? Valve damage causing not to close properly? Cracked head? I don't know. I just hope not the last one. By the way, I've seen pretty much lots of engine oil near the valves, and some CHRA debris that were stuck there. Here's a piece of debris:
Focus isn't clear, but it's metal.
Now, I'm a bit worried about T-VIS. In the video attached, you can see a little bit of play in the butterfly valves. Is this ok? Would it cause loss of power?
I'll keep you updated.
